Torx size
Old Oct 12, 2009 | 07:27 PM
scottysspeedshop's Avatar
scottysspeedshop
Default Torx size
I am installing my new PM wheels I got from www.costalmoto.com on my Ultra and need to know what size the torx is for the rotor bolts.Thanks in advanced.
Old Oct 12, 2009 | 07:45 PM
03dragonRK's Avatar
03dragonRK
Rotor bolts use T-40
Old Oct 12, 2009 | 07:55 PM
scottysspeedshop
Thank you .I will post pics tomarrow
Old Oct 12, 2009 | 10:06 PM
RKKY's Avatar
RKKY
T45 on rear rotor. T40 on front.
Old Oct 20, 2009 | 11:18 AM
ModusMan's Avatar
ModusMan
Stage I
Default T40 Torx and Rotor Removal
09 Rocker Custom - Trying to remove both rotors. Torks "Snapped Off" Unhappy tool guy. These are not reverse threaded are they? If not, then I think I am screwed.
Thanks for any input.
Modus
Old Oct 20, 2009 | 11:23 AM
Maimas's Avatar
Maimas
Thats some good lock tight.... Try a lil heat 1st...
Old Oct 20, 2009 | 06:41 PM
gunnert's Avatar
gunnert
Rotor torx bolts are installed from the factory with locktite. You'll need heat, e.g. oxy/ace, to get them loose. If you haven't done this before take the wheel to an Indy shop.
RHillbilly
EVO
14
Sep 1, 2015 08:40 PM
caddyman311
Dec 5, 2011 06:38 PM
Biker Bob
May 10, 2008 01:36 AM
05Fatty
Feb 5, 2008 07:38 PM
xlc06
Jun 19, 2007 04:26 AM
