Baker +1 oil pan - Has anyone used it?
Has anyone installed the Baker +1 oil pan? If so does it really lower the temp?
http://www.bikerrogue.com/Articles/T...er_Oil_Pan.htm
Teqs,
You could spend alot less and get the '09 oil pan and put that on your bike. It too is 'sposed to lower temps by design. Check it out. IF you do put the '09 oil pan on your scoot, you can then use the newer styled '09 pipes, with very minimal modding. A mechanic at our shop did this and he put the Vance and Hines PowerX Duals setup on his '07 and it sounds PHENOMENAL!!
