Stoopid question but...
Old Nov 24, 2009 | 03:03 PM
FLHTCU Owner's Avatar
FLHTCU Owner
Originally Posted by leon anthony
the oil is in a remote oil tank not5 in the engine I do not see haow the tank
being full makes the engine blow oil. My 06 ultre with 80000 miles does not blow
oil with a full oil tank
It happens on most. While it's technically true that the oil is in a 'remote' area, it does flow to the engine eventually causing pressure buildup. Too much oil (i.e. full) will cause pressure build-up into the rocker boxes. The rocker boxes vent to the breather. If the breather is cleaned, or re-charged before the oil change, then oil 'misting' is minimized. Scares the crap out of you the first time though.
Doherty makes a misting kit that will elminate this problem. There's probably others that do it too.
http://www.dohertymachine.com/index....6e3f43a8c40ab3
Old Nov 24, 2009 | 03:09 PM
FunkyNova66's Avatar
FunkyNova66
My buddy had the same problem. Ended up being the o-ring gasket between the backing plate of the air cleaner and the cylinders. If it is not sealed correctly, you will experience light blow-by oil mist on the right side. It will mist on your pipes just like you described. Do you have an aftermarket air kit?
Old Nov 25, 2009 | 04:42 AM
RoadkingDxb's Avatar
RoadkingDxb
Originally Posted by FastHoss
Ali Babba was trying to drill for oil in your bike.
LOL, don't think they need the oil from my bike, they have enough in the desert and offshore. Still, maybe I should wrap my bike in pork, that might keep them away. A true HOG.
Old Nov 25, 2009 | 04:44 AM
RoadkingDxb
Got an SE heavy breather without any sign of oil on the sock. I'll check the backing plate for seal. Thanks.
Old Nov 25, 2009 | 05:57 PM
bluesky's Avatar
bluesky
Did the service include lubing the steering head? Maybe over fill in steering head. When it gets hot & it runs down forks, it looks like it is coming from engine. Happened to me. Freaked me out at first. H.D. dealer using cheap lube. They make summer and winter lube.Ask for it next time.
Glock-45
Milwaukee Eight (M8)
11
May 12, 2019 09:31 AM
yokdriver
Aug 12, 2014 03:17 PM
mcdaniel52761
Apr 22, 2012 02:20 PM
old skool1983
Jun 15, 2010 08:26 AM
Bluerose
Aug 23, 2008 04:11 PM
