SE 255 Dyno Results
Lifters: I didn't replace the lifters because I thought they might fail. I'd read on here and talked to professional builders who said that when changing cams, you should change the lifters as well. Evidently this is done with cars as well. The issue is that the lifters/cams wear against each other and can create wear patterns. If replacing new on used, this can cause problems. I had a lot of miles on my bike at 34K. I checked the used SE cams (only 2400 miles on them) and didn't see wear issues with those, but chose the change the lifters to be on the safe side.
Low cost, low labor if done with the cams. Cheap insurance!
These are the same lifters used in modern GM cars and trucks, which often go 100k's of miles without lifter problems. How many of these vehicles have you heard of that've had lifters replaced?
Apples and Oranges.
I replaced the original big-axle lifters in my '96 RK at 65k as a precaution, left the second set in the bike up to 106k when I sold the bike (41k miles later), and they are still there at 120k even though the idiot new owner ran it low on oil for a short period. "It really rattled...." Yeah, I guess it did.
I won't fault anyone for changing theirs during a cam change, but I feel it isn't warranted in most cases, although I'm not sure what mileage would be the cut-off point for me to feel a lifter change was necessary.
I wasn't worried about failure of the lifters. Most of the builders I spoke to and my HD wrench suggested that new lifters would mitigate issues with different wear patterns. I'm not a wrench, but as I understand it, the lifters and cams ride on each other and can create wear patterns. Replacing one or the other without the wear patterns can create gaps. Don't know what gaps cause, but I figured that since I had everything opened up, I'd take out the insurance plan. BTW, I'm the one that asked my HD wrench about it... he hadn't brought it up.
I don't think "wear patterns" are an issue for roller tappets like they would be for flat-tappets. I've been told that wear is minimal for the roller tappets and cams, and when I replaced mine on my old RK at 65k I saw no wear on the cams or lifter rollers at all. I changed them only because I didn't know if the bike had the old "small-axle" lifters installed, which were known to fail, but even though it had the newer big-axle type I changed them anyway. I installed new lifters on the Andrews EV13 cams that had been in the bike for >50k miles and the bike is still running fine today on that second set of lifters at 120k miles. Had wear patterns been an issue I think it would've shown up by now on that bike.
Kingspoke
Engine Mechanical Topics
14
06-30-2022 06:11 PM
