Video of ignition switch removal
A word of warning. There are several waffers inside the cylinder of the lock. When you pull the shaft out be careful that the tool you make fits good enough to turn all the waffers at once. In other words make it long enough to go all the way through to the bottom. Also make sure the shaft is all the way in before you turn it or you will get the waffers out of sync.
I know this because once when I out one back it was not all the way in and when I turned it it moved all the waffers except the bottom ones and I had a mess. It took me several days of trial and error plus a service manual to get it back like it was supposed to be.
