Catalytic converter in 08 ultra?
that's what the Fulsac kit is supposed to do. Prior to the kit most of the exhaust came out of the right side and the left side was more for appearance.
There is not a catalyst on your 08, however the L & R mufflers do flow slightly different.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Pulled the mufflers off today with the thought of attempting to remove the cat(if there was one). No honeycomb cat visible in the right side muffler. However..... there is a huge difference in the mufflers. Right side is a half circle from both ends and obviously forces exhaust to run circles before exiting. Left side is wide open to a single baffle near the exit end of the pipe. Right side is also 2 to 3 lbs heavier than left. I am not sure why there is such a huge difference in the pipes, but I will be shipping them to fullsac for a 1.75" recore to even up the flow and sweeten the sound.
It is heavier cause the cat is behind those half circles. As to removing the cat, it doesn't work very well with touring mufflers. W/ softails and sporties use an 18 in 5/8 drill and just drill holes through it from the front end. It was much easier to remove the baffles prior to 06. All you had to do was take a die grinder to the weld at the back of the muffler and when you have completeley cut the weld, the baffle falls right out.
Bwana
Bwana
