I went the Radizant rear led's and bought the Badlands module that turns my turn lights into running lights: with the clear lens, tour pak led's with clear lens, my *** just glows going down the road at night:
This is the best setup. Change your tail light to the Radiantz along with your signals. Then add the Badlands Illuminator and you will be seen.
I am very impressed with the products from Ridetime. I installed the LED's on the tourpac as well as the mini light bar and a couple other lights.
Next to someone pulling a left in front of me, is getting rear ended and these are bright. In addition to the quality products, being made in the USA and the great customer service, you cannot go wrong here.
Do you know if these are friendly with HD Security system? Thanks!
I'm running the HD module (plug/play) part#69461-06A
switched all the bulbs to led from auto zone, so far so good. Much brighter. Almost forgot, yeah I've got the security system with no issues
I did this...removed bar and replaced with Auto-Gem Shotguns, removed turnsignal bar and added Randiantz LED Arrays and Badlands Illuminator and RideTime Tech smoked laydown LED tail light with bottom tag light.
If I get hit from the rear, the driver is BLIND!!!
Thank you for that info I am running hd run/brake/turn module also! Guess it's time to spend more money !
i have that light on my bike. very bright and it comes as a unit so you will have the old light around. Also check ther 40 led fender tip light. I plugs int the unit and makes the fender tip also a brake light.
