Say no to Headlight Trim Ring Crack
#32
You can save yourself alot of time and aggravation with a very simple solution I found that worked quite well. Before you even get started take the screw and nut to a good hardware store. Replace the screw with a SS phillips or socket head screw and reuse the original nut.
The problem with Harley's design is the screw. It simply doesn't have a large enough head and deep enough slots to provide enough leverage to close the ring gap without the head pulling through or stripping out the slots.
I found that almost all standard screws that thread into the stock nut will have a larger (better head) that will pull the gap together very nicely. A simple $.25 investment will make this job take but a few moments to install correctly each and every time.
#33
#34
It really shouldn't be that difficult to find. I believe its 1.25 or 1.5 inches long with fine threads. I would recommend getting it in stainless steel. I think I bought mine at Lowe's.
#35
It wouldn't have been hard to find if I had of been at work. We have 1000s of them there but I wasn't at work..lol. I may still change mine after I can locate one. Using the clamp to help close the gap, the phillips worked just fine.
#36
Good idea but I got the same results (no gap between the 2 ends of the trim ring) without using clamps. I loosened the stock ring bolt, mounted the trim ring over the stock ring, and tightened both bolts alternatively until both ends on the trim ring touched. This was easy.
But this doesn't solve the other issue. The remaining issue is that the trim ring sits away from the headlight glass. It leaves a 1/4" gap all around the glass allowing dust, bugs and water between the headlight and the trim ring.
From your pictures, it's the same for you.
Anyone has been able to mount the trim ring so that it contacts the headlight glass all around the perimeter? What did you do? I tried to loosen the adjustement bolts to no avail.
Note that there's no gap whatsoever with the passing lamps and turnsignals trim rings.
This headlight trim ring is very poorly engineered and I'm being nice when I say this.
#37
#38
The gap you speak of between the headlight glass and the ring does exist but the original ring on mine feels that gap preventing critters from entering or, at least, it prevents them from entering into the headlight bucket.
I have read where other folks have filled that gap with silicone and some have used insulating tape.
I think we are all in agreement that the design, of these rings, is a turd.
#39
#40
I like that idea. May give that a whirl. By the time I get all the kinks out of this one, HD will probably have a new design that actually works...lol.
