Damaged clutch hub splines?
Ron
I actually thought about that. I hate the thought of putting a new hub in that's gonna look the same the next time I take it out. I contemplated just clearing the loose stuff off and reinstalling the hub as is,,,,,,,,,,,,,,,,,,,,,,
but some how I just can't bring myself to reinstall something I KNOW is damaged.
Ron
Ron
my 2009 fxdc 30.000 miles, changed the drive belt & swingarm bearing. went to put the clutch hub back on & it's just like the photo. Also primary chain has worn against inner & outer primary cases at some point??? A few flakes of metal on the drain plug at 10.000 mile primary oil change but none at 20,000. I guess this has happened because the automatic chain tensioner is not correctly tensioning the chain until it's running. On initial start-up an excess of chain runs over the compensator sprocket catching the casings!!!! Clymer manual says to file off rough edges on broken splines. Dealer says clymer manuals are old school and just to keep the bike running. Dealer says only a new part would be fitted if they ever came accross this problem but they've never seen one...................lol basically the design is flawed & when it all goes wrong I'm going to run an open belt...........or buy a honda
5ft2 Giant (10-23-2019)
My experience with the stock hub on my 05 was the fit was very sloppy. I could have thrown it across the garage and it would have went on. The hub on my Bandit clutch was a completely different fit. It was supplied with lube and you had to work at it to get it to line up and once it did it slid on with a nice tight fit. The hub is also longer and has a taper on the back of it to mate with the taper on the tranny shaft.
Rick
Rick
