SILVERSTAR review
Old Aug 2, 2006 | 01:20 PM
Mikebiker's Avatar
Mikebiker
Default RE: SILVERSTAR review
Ya, D175 you should have. The headllight there is only one choice, part # H4ST , it's the only silverstar with a H4 base. Passing lamps I used are the 27 watt ones because they are the same wattage as the stock bulbs, there is also a 37.5 watt bulb ,but I didn't want to burn up the wiring harness ( not just yet anyway). Part numbers are ;27 watt - 880ST foglamp bulb and the 37.5 watt - 893ST foglamp bulb. I know soome older bikes use sealed beams in the passing lamps , I've read here in this forum that some of those guys use the H-D upgraded lamps. I have no personal experience with PIAA but I do have some friends that are into 4X4ing and they swear by PIAA. They are very brite, I have not noticed the washing-out of details by the lights but perhaps I'm not looking for details, just happy to put more light out in front of me.
Mike
Old Aug 2, 2006 | 03:05 PM
Ram's Avatar
Ram
If you go to Passing lamps with the H-D upgraded lamp assembiles then you can run the H-3 lamps made by either Piaa or SilverStar.
Old Aug 2, 2006 | 04:17 PM
jd_underdog's Avatar
jd_underdog
I have a 2000 roadking classic, are the lights on mine sealed or can i replace them with the silverstars?
Old Aug 2, 2006 | 08:44 PM
Ram's Avatar
Ram
If the lense you have looks like this below, you can use an H-3 bulb. If yours is stock and your the first owner an you didn't order any upgrade on Passing lamps when you received delivery then most likely yours will "not" accept the H-3 bulb pictured below.
[IMG]local://upfiles/4133/B7210F62CB58424B9E73969942EB6D20.jpg[/IMG]
[IMG]local://upfiles/4133/A4E3DD83436A4D2BBFE7649806A925F8.jpg[/IMG]
Old Aug 2, 2006 | 09:26 PM
HDCopper's Avatar
HDCopper
Will be orering the passing lamp kit for a Street Glide. Any idea what the part 3 would be for the upgraded lens? I am going to order everything from Zanotti's HD. Thanks
Old Aug 2, 2006 | 09:38 PM
SubZer0's Avatar
SubZer0
Any chance I can us these in a Road Glide? I am worried about heat and AMP draw under that plastic cover.
Old Aug 2, 2006 | 10:44 PM
HDCopper's Avatar
HDCopper
Anybody know the best place to buy the Silverstars and how much?
Old Aug 3, 2006 | 05:04 PM
suicide441's Avatar
suicide441
The amp drain is the same as stock and they don't put out any more heat. I have them in my RG
Old Aug 3, 2006 | 06:27 PM
Mikebiker's Avatar
Mikebiker
I bought mine at AUTOZONE paid less than $60 for all three. Headlight H4ST . Passing lamps 880ST
Mike
Old Aug 3, 2006 | 09:24 PM
SubZer0's Avatar
SubZer0
Thanks for the reply. Are they the same part number H4ST, for a RG?
ORIGINAL: suicide441
