Road King fast idling problem
On my way home today from work, my bike started idling faster and faster. I managed to get it home and in the garage before things got out of hand. Shutting the bike completely down and then starting it, the bike idles at what sounds like 3-4 time the normal RPMs and it seems to be getting worse.
I checked my throttle and idle cables, which appear fine. The throttle grip snaps back into place when released. The intake butterfly action mirrors the grip rotation perfectly, and is horizontal at full throttle and closed at idle.
I disconnected the battery for a while, blindly hoping to reset what may have been a temporary EFI bug. Problem persisted.
The Road King is stock with a Ness Big Sucker, Cycle Shack slip-ons, Fulsac dual exhaust conversion, and Power Commander III from Fuel Moto.
Last year, the local stealership claimed I had a crack in my intake module but I have been unable to locate it. I mentioned same to the local independent during some service and they never mentioned seeing it.
Anyone got any ideas? This has got me worried. I was planning on using the bike for a week long road trip starting this Friday. Doh!
2K,
Try this...To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position.
You may have a throttle position sensoe going out (TPS)
An air leak between the carb/throttle body will result in a higher idle RPM.
You did say what year your bike is.
I had an '08 RK with a fast idling problem, dealer showed me how to reset the idle as in the quote, and then he told me never to have my hand on the throttle when turning off the bike, just one finger on the kill switch. He said if the throttle is advanced even a little bit when turning off, it will increase the idle next time you start it. This worked for me, and seemed to solve my problem.
I just went out to the garage and attempted the throttle position reset as described by Hrod. Attempt to start after procedure resulted in high idle still, unfortunately.
The bike is a 2001 FLHPI.
Man, I want to convert this bike to carb more and more.
Fireaxxe, what is "IAC?"
Received 4,879 Likes
