Glide Pro v Sta Bo
I ordered the Sta-Bo. I had a look at the inserts that they sent which go into the stock bushings. Looked, OK, but a bit of a band-aid for a big problem. I reexamined the Glide-Pro site and called Jake, the owner.
We talked about the depth that the stock bushing go in and we discussed that his newest product does not fit inside the stock bushings, but replaces them altogether and the go in to the frame further, provided better support. The materials are also different and he uses a rod that connects both of the bushing.
Fortunately, I live in San Diego, so I took a ride down to his hanger at the airfield. We talked more and he reached in to a bucket full of stock bushings that he has replaced with his. I was shocked at what a cheap-*** part HD would have chosen for such a huge weight to depend upon.
I looked at his bushings and decided on the spot to replace mine with his.
I am very, very impressed with the results. Needless to say, replacing the bushings on an 08 does not give you an 09 frame, but the improvement is significant and was many times better than what the Bagger Brace provided even when it, and my stock bushings were new.
I can't say if the Sta-Bo would be the same, but after having compared both and seeing what a more complete fix the Glide-Pro was compared, I think Glide-Pro is well worth the added cost.
Jake, himself, is also a good guy. He installed them for me at no cost, a job that was around 2 hours, lent me his bike to go get some lunch while he worked on mine.
I would whole heartily recommend the Glide-Pro. I have a renewed happiness in my current bike and put off trading for a while longer.
I can;t answer tech questions ans I am not mechanically inclined, but if any one wants to PM me I can tell you what my experience has been.
Arthur
Arthur
PM sent
