How To Install a SE Pro Super Tuner ?
I have read alot of post here on the new SE Pro Super Race Tuner part #32109-08B. I just haven't seen how is the smart tune connected to your bike while riding to log info. Also, I have a PC-V with SE 255 cam. If I were to buy the SE Pro Super Tuner how would I begin the tuning since I have a canned map for the PC-V and that will be removed and the Stock ECM will be connected with the wrong download for the SE255 cams? Please explain how to begin and what has to be connect and how..thanks.
Along with the SESPT, you will need the software ($30) and the Dongle cable(s) which are $40. Remove left saddlebag/side cover. Your SESPT connects to your ECM cable between the dongle/computer. The SESPT only is connected when tuning your ECM, otherwise you keep it in your saddlebag AKA don't leave home without it. That said, if you already have a PCV, just stick with that. I went a SESPT because I got it new for $225 and their is a competent tuner 25 miles away. My thoughts only
gr82bagn
The Dyno Room
10-11-2016 08:16 PM
tully_mars
11-14-2011 12:51 PM
1931jamesw
06-18-2010 07:49 AM
