Street Glide Air Suspension Question
Street Glide Purchase
Okay great, sounds like a lot of chrome goodies. I hope the price is right. As far as the shocks go that's what I ran progressive 440's but I had them in 11". You didn't mention height. In any event shocks are easy to change and relatively inexpensive unless you go to the more exotic suspensions available out there. I believe the shortest you can get the 440's is 11" so this bike is definitely not slammed as you originally had been told. It's just as well because your ride would definitely suffer. The bike might handle better lowered but ride height is always a factor as far as how it takes bumps in the road. Shock travel will suffer as you lower the bike. Shock travel translates to how much the suspension will travel before it hits the bump stops in the shock. It also means that if you have no travel or alot less you'll be hitting that stop more often and feeling that jolt. Try the progressives for a while if you like the bike. You can always change out the shocks and certainly other stuff to make it your own down the road. The main thing is to be safe. Good luck with your purchase. Keep us in the loop and let us know how you do.
Sorry to disagree with Overdoo but if your shocks are 11" your bike certainly has been "slammed". The shorter the shock, the harsher the ride (due to a stiffer spring used on the shorter shock).
If you go back to the stock air shocks the change will involve re-installing the air lines and fittings. So the length of the Progressives is the key factor here. If they are the same length as the air shocks (12") you're good to go unless the bike is still too tall for you. In that case you have to do what you have to do, just as Overdoo did.
have you contacted the guy who owned the bike when it was changed over to being lowered? he may just still have the stock shocks. i have an 08 streetglide too, and i'd like to find someone nearby to swap my short shocks for their stock length electraglide shocks, being as i'm not short. who knows, platform shoes might come back in style.
G'day All;
The Reg here, from Perth Western Australia.
I am about to look at a 2009 Street Glide to buy and from this discussion not sure what the standard rear shocks are like for 'two up and loaded touring'. Are they Air Shocks like the electra glides? I had a 2001 FLHT which was excellent and after 6 years went to a Superglide and a Honda ST1300....but the 'Call' of the Touring Harley is strong again.
I think the standard rear shock travel is 2 inches...which doesn't sound like much. Any comments will be welcome,
Cheers.
Cheers.
As far as running the air lines and fittings it's all flexible tubing and couldn't be easier if that's the way she decides to go.
G'day All;
Cheers.
Cheers.
The air shocks on the street glide are the same design as the electra glide but I think the standard length of the EG is 13" where as as you have said the SG is 12". I think you"ll be fine by adding some extra air in the shocks. You have to experiment with how much. Check the manual for a starting point or do a search on here for what some of the others are running.
Cheers,
The Reg
