Notices
Change from 5 Speed To 6 Speed
  #61
Old 06-30-2017, 11:34 PM
Tactical111's Avatar
Tactical111
Tactical111 is offline
If you have a 5 spd and just want to cruise at high speeds a little smoother just add 2 teeth to the front belt pulley. Did on my '91 Evo and it worked great. Spend a lot of time at cruising speed so dropped the rpm's around 350. Taking off in 1st is a trip as it launches across the intersection. :-) Have an '07 Road King Po Po now with a 103 incher 6 spd and LOVE IT.
  #62
Old 06-30-2017, 11:37 PM
Tactical111
Question Cruisin'
Originally Posted by casique View Post
Huge waste of money! I hardly ever ride in 6 gear, even on the highway. Very seldom do I get up past 70-75 while riding.
I seldom get OUT of 6th gear. The first 5 are just the means to the end.
  #63
Old 07-01-2017, 04:49 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 1,772 Likes on 1,614 Posts
Wink
Even cheaper to wear ear plugs! Best tuning aid ever.
  #64
Old 07-01-2018, 06:54 PM
Sid Vicious
Sid Vicious is offline
New Member
2004 Sportster 883 with it's 5 gear transmission. I would like to
get a kit to a 6th gear OD
I'm in the Central Coast, I Love the canyon Rdies & back in the vineyards areas. I Love my 5 speed for doing all that. HOWEVER...
I'm wanting a 6th gear Over drive for longer trips of highway use.
I like my bike, eventually will do the boreing and build the 1200cc but I'm do want a 6th.
Any recommends on which tranny kits to use?
  #65
Old 07-01-2018, 07:43 PM
leon anthony
leon anthony is offline
OVERDOO
GR BROWN is usually right but he is wrong about the Harley 6 speed being a overdrive in 6 gear it is direct drive they get the same ratios as the five speed in first through 5th
because they changed the gear ratios in the tranny to match the five speed with changed rear pulleys that gives the 6 gear a higher ratio than the five speed therefore your friend would have to change his trans sprocket and his rear pull to a 07 or newer
  #66
Old 07-01-2018, 07:49 PM
leon anthony
Default Overdoo
Overdoo If your friend Puts a H D six speed in his bike without changing the rear pully and the transmission sprocket his top gear will be the same as it is now
  #67
Old 07-02-2018, 03:42 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
Originally Posted by leon anthony View Post
OVERDOO
The original H-D 6-speed was indeed an OD and the conversion for older bikes is still available. Later ones went to direct drive.
  #68
Old 07-02-2018, 11:11 AM
leon anthony
grbrown you are absoluety right I was not thinking a bout the H D 6 speed made for the 06 and down bikes
grbrown (07-03-2018)
lunar00
05-25-2017 10:00 AM
deadcat
04-07-2017 05:21 AM
Nick 93
09-16-2016 08:10 PM
nseverett
06-28-2016 09:04 AM
jjackhole
04-12-2016 07:24 PM
Quick Reply: Change from 5 Speed To 6 Speed
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
