Timken B-148 Inner Cam Bearing
HD pn#8983 roller bearing assy
HD pn#9198 needle bearings
HD pn#9215 needle bearing, cam
Personally, I would go with the SE 24017-10 B-148's over the other needle bearings.
those needle bearings are only going to fail in high HP motors where you have flex in the crank.
How would that even be a factor? Are you thinking of the crankshaft bearing maybe?
I like to replace any bearing if I'm replacing the shaft that rides in it. Things wear together, and I prefer a fresh start to allow for this. FWIW, YMMV.
Yeah, sorry. My brain runs faster than my fingers. I was thinking of the crankshaft bearings not the cam bearings. I also agree with you on replacing bearings if you change the post is a good idea.
Do a search for Georges Garage. He sells the bearings for around $15 including shipping. .He also sells all the tools you would need.Here it is www.georges-garage.com
