FYI `09 Road Glide fairing
2 Attachment(s)
Just over 8,000 miles and I decided to upgrade headlight bulbs. Thanks to this forum giving me the heads up I noticed the radio brackets chafing about half way thru at the windshield area. I`m going to take this up with the dealer along with the front tire cupping and a paint problem on rear fender. Also a big thanks to fixmyhog.com for videos of removal and installation of the fairing. It`s not too bad of a job.
Mine had only slight contact marks, so I split a 2" piece of gas line and slid on top of both brackets.
Also put 2 layers of duct tape on the inside of the fairing. Good thing you checked it when you did. Keep us posted on how your dealer treats you. |
I noticed the same on my 09. Took a dremel cutoff wheel to the bracket to shave it down some, filed it smooth and then put a piece of gorilla tape over each bracket as a wear indicator for next time I take it off.
took it to dealer to be looked over
Took a CD of several pics of the fairing to have the dealer give to the H.D. rep. and will be hearing from them. I also mentioned the front tire while I was there and they ordered me a new one. The tire had 8500 mi. on it. The owner of Racine H.D. (in Wisconsin) is very cordial and said they`d take care of me.
mine had just slight marks and i also cut the top of the bracket off.doesnt seem to rub now.dealer took care of my front tire no problem.
Harley screws up fairing. won`t fix until it rubs thru
Originally Posted by lowflyer
(Post 6877173)
© 2024 MH Sub I, LLC dba Internet Brands
