Hard Start When Hot
Old Oct 16, 2013 | 10:00 PM
Scubamike's Avatar
Scubamike
Originally Posted by btsom
Several different problems blended together here, first the OP. If your starter is having trouble getting through the first compression stoke but NOT accompanied with any bang or grinding noise, it is a weak battery or bad connections in the starting circuit. You need to check both ends of both battery cables for clean and tight connections. If they are good, put a digital volt meter on the battery and watch it as you hit the starter. If the voltage drops below 9.6 the battery is "tired" (needs to be replaced) or undercharged. If you have about 14.5 volts going to the battery while the engine is at 2000 rpm or above, the charging system is good and it is pretty solid that the battery is on the way out., UNLESS most of your rides are of short duration and there isn't enough time to fully recharge during each trip.
Now for the bang and grind. From 07 through 10 with the 96 and 103 engines, the compensator was a design left over from the smaller displacements and in most cases just wasn't up to the job. When the starter engaged, the weak compensator would run right to its limit and slam against its stop placing a heavy shock load on the crankshaft and back through the primary chain into the starter drive. That bang was the comp slamming its limit. The starter drive includes a sprag over run clutch. The design consists of some short, fat needle bearings sitting on ramps in the drive hub. When the hub is driven (starter engaged) the needle bearings run up the ramps until they are jammed between the ramps and the clutch housing. It is a simple design that works pretty well until it gets "beaten to death" by the repeated shock caused by the weak compensator. When it slips, it makes that terrible grinding sound as the needles rapidly try over and over to get a grip on the housing. If the starter drive is replaced without replacing the compensator, the beating to death process starts all over again. If the compensator only is replaced, you still have a well worn starter clutch which will fail fairly soon. Replacing both is needed for a long term fix.
Failure to energetically crank through the first compression stroke is an electrical problem, while the bang and grind are mechanical problems. The first is most commonly fixed with a new battery, while the second requires some expensive replacement parts.
Well put and IMHO spot on, I just did not have enough time to respond that long. Great job explaining.
Old Jun 25, 2017 | 05:34 PM
ryder2u's Avatar
ryder2u
Default would appreciate your opinion......
hope you can help .... sorry I know this is an old post but you had what I feel was the closest match to my bikes issue.... however as I lean on the starter "weak battery" waiting for it to climb over the compression stroke as is begins to rotate the engine fires with a "super high idle" then the code light puts up a Loss of Idle Control code...... only does this when the bike is hot and not allowed to cool before restart...?
given that input would you still say throwing a new battery at it would solve it? the beast in question is a 2012 FXS 103 ...
thanks in advance .... even if you don't reply tossing a battery would be cheap fix!
Old Jun 26, 2017 | 05:04 PM
JimTJr's Avatar
JimTJr
NO TUNER will fix this, it is the compensator, Harley puts a better on in the SE bikes,, My dealer tried to beat me up on that when I traded my 2010 in, I told him, ALL of them do it, you should have expected it when you quoted the price. Hot bike, kicks back, almost like a low battery. He didn't get me to budge on my trade, and I left with my 15 RGS!
Old Jan 23, 2018 | 03:25 PM
kneesinthebreeze24's Avatar
kneesinthebreeze24
My bike is in the shop right now for the OP issues. Did the OP ever find out what was wrong??? I will post up when I here from my mechanic.
2009 heritage, 20k
Old Jan 24, 2018 | 05:41 PM
kneesinthebreeze24
I know this is an old thread, but I post up my results anyway for future reference.
BTW, my bike symptoms were the same as OP. Hard time starting ONLY after the bike was hot. Ends up , bad compensator. Replacing with the screaming eagle comp.
Old Jan 24, 2018 | 06:13 PM
SBates08's Avatar
SBates08
Your starter clutch has been weakened as a result of the bad Comp as well. Keep it in the radar as well.
Old Jan 24, 2018 | 11:26 PM
nytryder's Avatar
nytryder
If you do not have a battery tender get one. If that is not helping much a new starter clutch should clear up your issue.
Old Jan 25, 2018 | 08:07 AM
Magnut1's Avatar
Magnut1
I used to have a 70 GTO Judge (I know, still kicking myself) that would start hard or not at all when hot, I finally changed to 4 gauge positive cable and 2 gauge ground and made sure the block was clean where the ground strap secured. Never did this again. I have had one other bike, my O6 that had a problem like that also, checked the ground cable and it was loose from the factory, the turd linesman cross threaded it and instead of correcting it, let it go. Had to replace the batter under warranty. So check the ground and positive to the battery, and where the cables attach to the starter and frame.
cerelious
May 1, 2023 09:35 AM
bmorebhoy
Jul 3, 2012 08:09 PM
Wayne54
Mar 28, 2011 12:24 PM
DeluxeRealtor
Jul 28, 2009 12:17 AM
77ironhead
Jun 18, 2007 01:23 PM
