New Wood Knight Prowler TW-555 Cams
That's EXACTLY what the advance gear would do for you. As a matter of fact I would have gotten that if I knew more about it at the time of the cam install. If I remember correctly, it would have only been an extra hundred dollars, but we never discussed it until after the cam install and tuning were done. In hindsight I would have done it, but I'm definitely still loving what Jamie's set me up with.
If I'm real lucky next year (or so) I'd like to do a cam and possibly a head swap, so I'm looking to see what you get out of that 103 Jamie.
Question though Jamie, I'm told the 103 on the Limited is the same 103 I have in my '09 Police Glide. If so, when I looked up the part numbers I noticed the heads (and cams) on my 103 are the same as the 96 motor. It would seem the heads would choke it a bit, all else being equal. Would a head change make a difference enough to warrant a $1K+ investment? Probably more $ than that I'm guessing.
For now Jamie, I'll be tickled to death if the AutoTune maps will give Keith some insight as to why my bike runs so horrible. Very cool you guys are willing to look into the problem. Thanks for that.
Oh, and post a video too after that cam install to give us little treat for the ears!
Hey Jamie,
This is Alan, the guy who sent you an '09 ZX-10R Power Commander 5 to be retrofitted for an '06 ZX-10R.. You should have got it today...
Anyway... Since we are talking Harley's and Wood cams, how would this new TW-555 compare to the TW-408-44?
Isn't that what the TW-408-44 was designed to do? Go in the 103-107" 10.5:1 compression bikes?
I'd love to hear more on this... It is gonna be interesting to see your results of those three builds.. I'd send you a set of TW-408-44's to swap in and out to compare as well if you'd like.
Alan
Alan
is the woods 555 like the se255?.......my 103" felt a good bit stronger with the 255 from idle to 3k than with the tw6-6 that's currently in it......a little above 3k the tw6-6 might be a little better at least the per the dyno sheet it appears to take off...although..I can't tell much of a difference riding........the hp and tq peak higher with the tw6-6 on the sheet...but it's just not at an rpm where I ride......day to day riding I preferred the 255.....I'll either be going back to the 255 or going bigger altogether w/head and internal work........going to talk w/my tuner and decide soon.....
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
