How do you take off the factory Brake Pedal Pad?
Granted, there are some things I've had to tear up to remove, but this certainly isn't one of them. The secret is to lift the rubber nub (which is into a V in the metal) with a slotted screwdriver coated with dishwashing soap, molded into the inside EDGES. Do the top one first, the nub is located midway on the pad. You will see a bulge from the outside as you pull and rock the pad. Then do the bottom edge. The pad will slide right off, no damage to the pad at all. Of course a knife, dynamite, portapower, chain off you truck bumper all will work also.
there is on my 2010.
How to Remove Brake Pedal Pad,HD fat boy Lo 2011
For anybody that's trying to get off the brake pedal pad, Midway inside the rubber pad there are two rubber notches that are grabbing the metal plate so if you squirt a little WD-40 inside midway through the rubber pad with a little muscle you can slip it right off.
Received 4,354 Likes
