plug crossover pipe?
Old 04-12-2014, 07:59 PM
purgatory's Avatar
purgatory
purgatory is offline
Default plug crossover pipe?
could you plug the crossover pipe on a 2014 streetglide for a "do it yourself"
2 into 1 exhaust kit?
Old 04-12-2014, 08:20 PM
Turret_plug's Avatar
Turret_plug
Turret_plug is offline
I'm sure I'll get flamed...... Because I'm not a horsepower junkie, but I really don't see why not..... With the catalytic converter in there, it's bound to build up more heat, and I think that's a bad thing.
Old 04-12-2014, 08:23 PM
kwo51's Avatar
kwo51
kwo51 is offline
Wonder that myself.
Old 04-12-2014, 09:17 PM
motsknab77's Avatar
motsknab77
motsknab77 is offline
NO, The pipes are set up for equalized pressure, the amount of air going in at the breather needs to be equalized by the pressure being exhausted. You may have heard about having to get your bike remapped if changing the mufflers and the breather, that is because the air in to out has changed and the EFI can't adjust to the different flow. You can cut out the Cat, but need to have an open pipe welded in, especially if changing mufflers. Old carb systems yes you can cut and hack, but not on any post carb machine
Old 04-13-2014, 06:46 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,410 Likes on 880 Posts
It should work - the left muffler doesn't get much flow. Official 2-1 headers still use a 1 3/4 inlet muffler don't they? Get a freeze plug from an auto parts store. If you don't like it it's easy to go back. You may have to remap but that's no big deal.
Old 04-13-2014, 07:08 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
...or if you want a "slicker" look, get a 2010 FLHX stock header- they were 2/1 for that one year.
Those headers show up used all the time as some demand the "traditional" 2/2 look.
Mike
Old 04-13-2014, 07:35 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
bigdumbnoitall00 is offline
once the 2 head pipes merge into the collector its a 2-1, or 2-1-30 it really doesn't matter how many pipes come off the collactor. the extra muffler might as well be a ghost pipe.
trunomad
11-25-2020 06:38 AM
1200low
03-22-2014 06:12 AM
fatbob
04-02-2009 12:17 PM
04ctd
Exhaust System Topics
08-13-2008 10:13 AM
Crazy Canuck
11-08-2005 07:59 PM
Quick Reply: plug crossover pipe?
