Citizen Band Radio
Citizen Band Radio
I know this might be in the wrong place but I thought this is where the people with the know how are. I have an 06 Ultra. I put a J&M headset on in Oct last and now my CB doesn't work. I contacted Iron Cross Audio and he mentioned there was a problem between Midland and Hd on the 06 model CB. So here is my question, Has anyone heard of this and found anything about it. Who can I talk to, to get this fixed. If you have someone at the MoCo that can help then please let me know.
Thanks
Thanks
There is no Tx Or Rx. I have tried to get other bikes to hear me but there is no break in squelch for them and none on mine when they Tx. I have tried using my auto CB and the only way I could get anything is to have the auto detuned to a different channel either up or down I can not remember which. I have tried using the old HD head sets but that did nothing either. Ran the radio self test and nothing found.
Thanks
Thanks
Carl
silverEarl ,,,,,
top left button on the radio I believe ,, Labeled "Com" ,,,,, press it, now display will show CB with an on/off icon in the display ,,,,,
press the button next to the icon to turn the CB on ,,,,, then immediately reduce the squelch to minimum using left handlebar control ,,,, adjust to desired channel using the right side handlebar control ,,,,
then adjust the volume of the CB using the left handlebar control,,, and also push the speaker rocker switch right below the radio to the all the way forward position to bring the CB audio into your helmet headset ,,,,
when you have the CB all set up the way you want ,,,, now press the "Com" button again to return all other functions to the audio system ,,,,,
please let me know how you do ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
