Big problem wit LED's need help
I have installed the Kuryakyn Deluxe Panacea Smoke Taillight model # 5401 with the Bullet Light Rear Turn Signal Bar model # 2098. I have also installed a Badlands Load Equalizer III, this is inline with the Kuryakyn control module. I have had numerous problems but the latest go like this;
1) Put bike in "N", and back down driveway into street, light goes out, the cause is a blown fuse. (Lighting Fuse, position 12, 15A). 2) I know this sounds stupid but if I don't back up the lights will work fine for a day or two. 3) Or if I back up with all the power off, I am ok. HELP!! |
Check the pins in the badland, when you back up you are prob putting pressure on that adapter under your seat. Maybe the connection gets broken. Just a thought.
Thanks I will look at that tonight when I get off work and let you know.
| All times are GMT -5. The time now is 03:33 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
