HELP Zumo Road Tech 665 Install
That might be the "correct, HD way" to wire it. For me, I wired mine to the back of the cigarette lighter. This required pulling the fairing off.
There is an extra existing power supply lead already at the headlight wiring. This is the simpliest place to get the power from and was specifically put there at the HD factory for this purpose. This is switched power which is exactlly what you need for the GPS. All running the lead to the battery will accomplish is increase the labor charge for the dealer, which you will pay.
Sounds like the dealer is pulling a fast one.
Yep, that's what I did
Update
I decided to go back to the dealer and have them explain what it is they are doing, The Harley way is to wire it to the fuse box on it's own circuit. The only wire that runs back there is the power for the cradle. On the 2011 there is a plastic cable tray running under the tank the wire needs to go in. He had one torn apart in the shop and showed me.
I would normally do this myself and pick power up in the fairing but I got a pretty good deal on parts and labor, 25% off and two year warranty. So in doing the math, if I did it I would end up paying about the same with just the manufactures waranty.
Plus he is already pulling the fairing off to paint the inner fairing so while he's at it, might as well install the system.
http://www.harley-davidson.com/gma/g...bmLocale=en_US'
I have one new in package for $20.
There is a mount for under the fairing but i don't see it on the HD site anymore.
