What is the largest tire that can be used on an 07 street glide. I have a 18 x 4.5 wheel. Will a 160 tire work or should I stick with a 150? What name brand tire is best or will fit better?
I have a 2008 FLTR (Road Glide) with 18 inch rims on front and rear. The largest tire that I can use is a 150/70 B18 Metzler ME880. Good luck on the 160 - I'm not sure if it will rub.
I would stop at a 150 metzler ME880. I had a 150 Metz on my 07, it measured
6 1/4'' wide on the bike. A 160 Elite 111 only measured 5 3/4''. Not very much
room left with the 150 Metz, anything wider and you're pushing the size of the
stock rim.
You can run a 160/60/18 Metzler ME 880, that is the maximum. I will tell you though that it handles better with the 150/70/18 and that's what I will be going back to next time I buy a tire. Above 75 MPH, the 160 is a little squirrely.
I have an 07 SE Ultra with 160 / 18" on the back and it fits. That is as wide
as you can go. I agree that the 150 is probably the best way to go for the
hiway speeds and will also go back to that when this 160 wears out.
