How to Identify ABS Option
How do you determine if an Ultra Classic ('08) has optional ABS? Is there a black box? Does the VIN identify the option?
Check under the right side cover and see if you have the ABS box under there.
If you still can't tell, PM me your VIN and I will tell you if you have it or not.
Originally Posted by Geoff
(Post 7581888)
There is a sensor the size of a quarter in the brake rotor
and an extra line going to the caliper
All of the above... And, there should be an ABS icon on the gauge that blinks until the bike hits 3-5 mph. This is the case on '09+, but not 100% sure about '08's.
The front wheel spacer on the left side will be black with ABS. Without ABS it's silver and looks like any other model year.
Originally Posted by houstonhdguy
(Post 7581960)
I say get it up to around 60 mph and lock down both brakes as tight as you can! If you don't crash, it has ABS.
© 2024 MH Sub I, LLC dba Internet Brands
