Sorry to have highjacked the OP's thread but I saw this on a CVO at the dealer the other day and kinda fell in love with the look... Hopefully this will help others as well.
Below you said you spent $539 at Zanottit. Was this a typo? I thought you said you didn't buy the CVO fender.What did you buy and what part numbers for that kind of money. Also do you know the difference from the PYO universal set up to the standard stealth one?
Thanks
I didnt buy the fender.Thats why I purchased the universal stealth plate3, to delete the factory turn signals and brake light. The fascia with the fender it was $686- Im using my stock fender with the cvo fascia. The standard stealth is for recessed fenders like the bagdad or sinister custom fenders.
If I am reading correctly then I don't have to buy the cvo fender as long as get the stealth plate bracket to cover original light bar holes?
Thanks for all the help and part numbers.
You dont need to buy the fender. If you dont buy something when you delete the tail lights on a 2009 you will have a big hole in your fender where the brake light used to be. On the 2010 guys are buying plugs to fill in the two turn signal holes.
If you look close at the two fenders, you will see one is a cvo fender and one is stock 2010 fender. The first one is a cvo fender the fender is smooth. The second one is a 2010 fender, you can see to painted plugs above the license plate thats where the turn signal bolts where. You dont need the cvo fender, its a preference rather you want to plug holes or not. I have ready many threads, I dont have the parts yet. This is just how I take it.
