Fumes, Fumes and more Fumes!
I have an '06 SG and since almost new, when I let off the throttle either to shift or slow down I smell exhaust fumes. It's not every time but I'd have to say it's most of the time. When I get through riding my clothes usually smell of exhaust. Needless to say, it's very annoying while riding. My bike has been on a dyno multiple times and is running around 14 to 1 across the rpm range so I've been told it's not running overly rich.
Also when I park my bike in the garage after riding the entire garage smells of fumes. Like a mixture of exhaust and gas. The smell in the garage will last an hour or two.
I have been to the dealer and a few indy's but they either say thats normal or they just scratch their head.
In a recent letter to tech Q&A in Rider Magazine a owner of a '07 SG experienced gas odor for three or four hours after riding and he stated that the longer he rode the worse the smell of gas when he parked. He replaced the fuel cap, overflow hose and vent valve with no success.
The tech responding to the letter said to replace the plastic vapor valve (part# 6215085) which may be cracked and to replace the "O-ring" which seals the fuel line quick disconnect. Both are under the fuel tank.
Has anyone on this forum experienced anything similar to what I've explaned and if so are you living with it or did you find a solution?
Thats an old picture of my bike, the turndowns have been long gone. Originally I thought the same thing, thats why I changed them.
Ever notice the back of a van or semi trailer that has been driving in a snowstorm or on dusty roads? Turbulent air/ backwash is blasting that dirt/snow against the back of the vehicle. Same principal applies to the motorcycle and the bigger the back end of the mc, the more noticeable it is. When you are cruising, there is enough exhaust pressure to pop the exhaust away from the bike, but when coasting in idle, there is not enough exhaust pressure to clear the bike, thus the smell.
Slash cut mufflers with the slash up and tourpacks with luggage on top will add to the backwash.
That's my story and I m stickin' to it
Bwana
Bwana
Bwana
Bwana
What kind of pipes you running? I had Rhinehart true duals and the rear cylinder head pipe was cracked leaking exhaust fumes. I fixed that but still had some smell like you describe.
Eventually I had so much exhaust smell that people riding behind me started to complain.
I could smell it too at 65 mph. To me it smelled like gas but to them it smelled like gas and oil burning.
Turned out my valve guide seals were bad. Not bad enough to make the bike smoke but bad enough to cause the odor. I did a big bore kit with new heads and problem solved.
I have heard that 06 was a bad year for valve guide seals???
Are you using any oil?
