Swing arm bushings?
Received 47,786 Likes
I'm confused, my mechanic says I need new swing arm bearing/bushings on my 06 Ultra. I took it too another guy & when I asked him about the busings, he looked at me like I'm an idiot & said he's never had too replace them nor has he ever heard of em going bad. Has anyone ever expierenced this or know of someone thats had to replace their swing arm bushings? Or am I being duped for some of my hard earned cash? The bike only has 27K miles on it cant imagine the bushings being shot already. Need advice from some bros.
If this guy said that the bushings are inside of the swing arm than this is a person needs to read the manual. There are bearings in side of them since 2002. Earlier models had cleve blocks inside of the swing arm which are made up of rubber and a metal sleeve. The bearings are crap that HD puts in as they only have a side load of less than 100 pounds. We are having 1,200 pound heavy duty bearings made for replacement. I have found that the swing arm bearings last around 40K mi.
The rubber isolator "RUBBER MOUNT ALL" 47564-86B fits into BRACKET rear fork, right (or right) ALL. It takes a while for that to go bad with usually oil damage.
You may try reading a manual for the insite
Are those heavy duty bearings for a private project, or do you plan on selling them.
Thanks Howard, do you have an estimated release date. It's funny that 2 days ago I was just talking to someone else about the OEM spherical bearings insufficient side load capacity. I was thinking of using 2 sets of thin thrust bearings, and position one on each side of a solid bronze bearing; 1 set for each side of the swing arm. There simply is not a motion requirement that demands a spherical bearing in the swing arm. Actually once the pivot axle is inserted through both spherical bearings it is impossible for those individual bearings to "wobulate" in a manner they were designed for; it’s absolutely the wrong type of bearing for the application.
