front wheel hard to spin on a 2010 flhtcu
Be sure after the axle is torqued, before tightening the pinch bolts on the right side, push in with your hand to make sure the right side is against the axle spacer. I had this happen to me after putting a new tire on. I tightened everything up and the tire was hard to spin. I reread the manual and realized I hadn't put pressure on the downtube before tightening the axle pinch bolts. This will cause misalignment on the brake to rotor.
I don't know how many miles you have on that 2010, but when I bought my 2009 Ultra I had it up on the jack and noticed the same thing: the front wheel was abnormally hard to turn (and I've turned quite a few front motorcycle wheels). After satisfying myself that nothing weird was going on, I just left it alone and rode it. Next time I had it up on the jack (say 1000 miles) it turned perfectly normally.
I don't know the reason; maybe the Brembo pads are just a little on the thick side and need to bed in to the rotors and wear just a bit before everything operates smoothly.
Just wanted to thank everyone for their responses. Remember that this was an issue when I stored the bike for the winter. So other then trudging out to the shed every month and making vroom vroom noises, I haven't seen or really touched the bike since late November.
Here's what I just found out. The wheel spins as it should. There should be a slight drag and you should hear the pads "rubbing". that's normal. I pull on the front break lever twice and wah lah-it's tough to spin again. I believe it's the LEFT side that seems to be hanging up. My next step is to (tomorrow night hopefully) take that left side caliper off and try to use brake pin lube on it. Only slightly. I'll see where I'm at and hopefully it's not the piston that's hosed.
At least I ruled out the bearings, over tightened axle nut or improper adjustment of the axle before tightening down the pinch bolts (like Ronp42 mentioned-that was a good tip ron).
your thoughts would be appreciated.
-Tony
-Tony
