How big of a job is changing inner primary seal?
Old 03-19-2011, 09:14 PM
brino's Avatar
brino
brino is offline
Default How big of a job is changing inner primary seal?
I need to change the inner primary seal on my 1996 flhtcu. Is this something that can be done by someone who is not a mechanic but is fairly handy around a garage and can read a manual. Is this a tricky job or pretty straight forward?
Old 03-19-2011, 09:23 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
If your comfortable with wrenches its a straight forward job with a manual in hand. This should give you some idea whats needed http://www.youtube.com/watch?v=XoZ4V...eature=related
Old 03-19-2011, 09:34 PM
Guntoter's Avatar
Guntoter
Guntoter is offline
That guy is a machine!!
sdguyman's Avatar
sdguyman
sdguyman is offline
I tried it twice and twice I ended up bringing it in to the dealer to fix. Its harder than it looks and I'm ok with the wrenches. I even read the manual and couldnt get it right.
Old 03-19-2011, 11:38 PM
bamclean's Avatar
bamclean
bamclean is offline
I've done it a few times without any issues...an impact wrench and the proper sockets are all you really need. The manual will get you through it. Go ahead and replace all the seals you can while you have it apart.
Old 03-20-2011, 01:50 AM
denalion22's Avatar
denalion22
denalion22 is offline
Dude easy job I mean easy put your oil pan under Tge bike grab your allens and wrench away. Pull The primary off. Clean your mess pop The new gasket on tighten the bolts add your primary oil and bam done.
Old 03-20-2011, 06:16 AM
CLL375's Avatar
CLL375
CLL375 is offline
^ If Kid Rock can do it; you can too!
Old 03-20-2011, 07:06 AM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,518 Likes on 3,048 Posts
Yeah, but don't ever use an impact on the clutch hub. 80 lbs torque with a left hand thread. That's why God created torque wrenches.
Old 03-20-2011, 07:44 AM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
Simple job. 2 hours tops, if you've never done one.
Old 03-20-2011, 09:44 AM
SC_Compact's Avatar
SC_Compact
SC_Compact is offline
What did he mean by the hard part unbolting the starter?
Quick Reply: How big of a job is changing inner primary seal?
