Radio Shack - Alarm Siren Install - 2011 RGC
I will contribute this thread for those doing it on a 2011 RGC
Just want to contribute a few photos. Nothing that has not been said or done... just my way to help someone else that might have questions. Process is for a 2011 Road Glide Custom Useful documents: Install Instructions User/Owners Manual (Page 77-78) Parts needed from Radio Shack: 273-079 - 12VDC Piezo Siren (US$5.49) 276-1427 - 9 Pin Male Crimp-Type D-Sub Connector (US$2.19) http://forums.rennlist.com/upload/alarm_sirensm.jpg Procedure: 1. Follow the instructions in the owner's manual (page 77-78) to remove the left side saddlebag. http://forums.rennlist.com/upload/dsc04321.jpg http://forums.rennlist.com/upload/dsc04323.jpg 2. Gently pull the side cover from the frame downtubes. http://forums.rennlist.com/upload/dsc04325.jpg http://forums.rennlist.com/upload/dsc04326.jpg 3. Put them aside carefully so they do not get scratched. http://forums.rennlist.com/upload/dsc04329.jpg 4. Pull the main fuse (40amp orange fuse... can't miss it!) http://forums.rennlist.com/upload/dsc04330.jpg 5. Pull Plug with three wires. http://forums.rennlist.com/upload/plug_copy7.jpg http://forums.rennlist.com/upload/dsc04334.jpg 6. Decide how you will install the wires from the alarm to the plug. In my case I used the pins. Peel about 1/2" of the wire, slide it in the pin. If done right, the wire should go inside the pin. I soldered just a small part to the crimping area before bending the tabs. As someone, I drilled a hole on the base where the plug was stored, to pass the wires and then connected to the plug. http://forums.rennlist.com/upload/dsc04339.jpg 7. Red wire from siren goes to Brown wire from plug. 8. Black wire from siren goes to Green wire from plug. 9. Secure the siren with double face tape (I used the strong stuff from 3M) and put a tie wrap just in case. http://forums.rennlist.com/upload/dsc04340.jpg There is a nice cut out in the place where the HD Siren/Pager module goes. Just looked like the perfect place for it. imho of course. http://forums.rennlist.com/upload/dsc04343.jpg http://forums.rennlist.com/upload/dsc04345.jpg http://forums.rennlist.com/upload/dsc04341.jpg 10. If, like in my case, you drilled a small hose to pass the cables into the storage for the plug, just know that the pins with the plug is longer that the space to put the plug back in. If you try to push the plug with the pins in place back into the plastic storage you will bend the pins... so don't try it!!. I drilled a small hole aligned with where the pins would touch the bottom of the housing to allow the plug to go in all the way. Put some silicone to seal it off. Also put some silicone in the hole where the wires come out to the siren. In my case, I ran out of black silicone and ended up using some blue silicone I had. I need to go back and replace that with black silicone... yes yes, nobody is going to see it, but I know and it will drive me crazy! http://forums.rennlist.com/upload/dsc04347.jpg 11. Install the 40amp fuse. 12. Validate everything works before you install back the covers. 13. Admire your work... drink your favorite installation fluid. 14. Install cover. 15. Install saddlebag. 16. Admire your work... drink your favorite installation fluid. 17. If the bike is not in flames the next day, you did everything fine. Admire your work... drink your favorite installation fluid. Please know that testing at 11:30pm might not be a good idea... specially if the door from the garage to the house is open. Just trust me on this one. You will get a "chirp" when the alarm arms... a "chirp" when someone moves the bike to warn them... and then it goes full blast. Turns off when you come back from the house with the fob and your wife is screaming at you for doing all this crap when the children are sleeping... |
Here is the link to the 3 place metri-pack connector needed that I posted on the other thread in the other forum if you want to make it look factory without having to splice and run it through the dummy connector.
Nice write-up. Well done. I installed this on my 06 and am very happy with the results.
Originally Posted by dawg
(Post 8071319)
Here is the link to the 3 place metri-pack connector needed that I posted on the other thread in the other forum if you want to make it look factory without having to splice and run it through the dummy connector. Have to buy pack of 10 but I'm sure you could split them/sell them with others doing this mod.
I need to order it to make this install look properly finished!! :icon_dance-tap: |
Thanks for the pictures and the link for the connector. Sure makes it a lot easier!!
Great post. The only thing I would add is a remote weather proof hidden toggle switch spliced between the hot lead to the siren. A "valet" switch so you can turn it off when sent to the shop or if you are planning a ride to an event that you wish not to "announce your presence" or if you are parking somewhere you have people you trust that may need to move your ride.
nice write up, I'll be doing this soon
Originally Posted by zfdtruckman
(Post 8138952)
On my 2010 limited the alarm set automatically when I walk away with the fob. The fob does not have any buttons on it. All automatic.
Originally Posted by Flintshooter54
(Post 8144792)
© 2024 MH Sub I, LLC dba Internet Brands
