AlanStansbery |
03-27-2011 09:35 AM |
My throttle linkage has been 'sticky', before. I had to adjust it...
The first thing I'd check and try to rule-out is the mechanical action of the throttle, the dual cables. First, I'd lube the cables. Then, at rest, with the front tire (bars) pointed straight ahead, with engine OFF, if you give it 1/4 to 1/2 throttle, then let go of the grip suddenly, does the throttle (carb or throttle-body linkage) 'snap' back to idle ('0' throttle)? If not, there's an issue. I'd try this test at full right lock (bars) and full left, too. There's a procedure in the manual for adjusting the throttle cables, if memory serves. If you're at all handy with tools/procedures (AF Crew Chief?) then it's well within your means. If the throttle returns to idle with a 'snap' in all three positions with the engine off, be careful and try it all again with the engine running. Don't crank in too much throttle of course, and don't hold it too long. If you have a sense of the throttle position that's 'sticking', put in only that much 'twist'. If the throttle is sticky with the engine off, problem's likely mechanical. If it's good engine-off, but 'sticks' with engine running (the cables return to 0 fine, but idle stays high), you've got something else going on... Good luck with it... Alan
