Installing SE compensator kit w/pics
#591
bait and switch
let everyone upload and post links for years.
Then one day they decided , hey we will charge you to keep those links active
Real Dipshitssss
#592
Photobucket Breaks Image Links Across the Internet - Article
http://www.denverpost.com/2017/07/06...over-charging/
_
soft 02 (08-24-2017)
#593
For those of you changing out your compensator. Don't get ripped off by HD for the glue. HD sells us the glue Maxlok MX/T6 for roughly 46.00 then you have to purchased the grease gun adapter for another 5 or 6 bucks. You can get a "REAL KIT" glue and grease gun adapter for 22.50 then 13.50 FedEx shipping.. Go to www.Chembar.com you want the 50ml kit Maxlok MX/T6. If you are a maintenance type, this will be enough to do three new SE Compensator kits.
#595
I decided to go with the "grind the primary case" method vs. removing the inner primary or loosing up the inner primary. Grinding seemed more simple with less parts having to be removed.
Here comes the part when you have to remove/grind material from the primary case to allow the rotor to be removed. I used a die-grinder with a cone shaped de-burring bit. Not much material needs to be removed and the total time to grind was less than 3 minutes. The pic below shows why grinding is needed.
Use care to cover everything in the primary and surrounding areas with towels/rags to help contain the metal that is ground off. I had my wife hold the shopvac in close while I did the grinding and almost all of the debris was sucked up. The case is aluminum and very easy to grind, use slow speed and it's done in short order. The pics below show protection for the grinding process and where the grinding is done... also the stock rotor removed.
Once you're finished grinding, grab the stock rotor and pull it off. It's has strong magnets in it so you have to get a good grip to pull it free (I used a hook tool to help pull it towards me). Hopefully you have enough material ground off to allow the rotor to clear the case... I was lucky and it came off first try with just a couple of wiggles. If not, then grind a little more until it clears and can be pull off. Vacuum up any debris and remove the towels, make sure you wipe up any particles left from grinding.
Of course my service manual also shows a guy simply grasping the rotor with his hands and pulling it out, and I don't see how that would be possible either.
#596
Does anyone have any tips for removing the rotor without removing the inner primary or grinding on it? The service manual doesn't say anything about grinding the surface of the inner primary or removing it, so I would hope it could be removed without either of those steps, but it sure doesn't seem like it.
I believe it depends on what year original compensator you are replacing. If you have a pre-SE (pre 2011???) you must replace the rotor, and grinding is very easy, you only take off a little at t time in a small part of the outer primary.
If you are replacing a SE compensator or a stock 2012-2013?? you don't need to replace the rotor so no grinding is necessary.
So That is the question I would ask...and y0u should indicate what you have for year of bike and is it still the original comp. I'm pretty sure that grinding a millimeter or two off the ridge in the puter primary is much easier than following the service book and removing the clutch and outer primary.
I'm investigating replacing my 2012 stock SE compensator with the 2014-2016 version that has the oiling tray. I think I just need the 42200064A compensator and some JBWeld.
#597
#598
I installed a SE comp kit yesterday in my 2009 Ultra and took pics to help anyone that's going to do this upgrade. All this info has been posted before on all the different HD forums but I personally like the how-to threads with pics and wanted to give back to the forum so here was my opportunity to do so ...
The main reason I wanted to do the upgrade? In stop and go traffic when you have to creep along feathering the clutch at low RPM's I would get that annoying "shudder" coming out of the primary. It feels like gear lash or a sloppy drive train. This is due to the weak spring design in the stock comp. Also the loud BANG at start up made me want to switch out to the SE comp.
I did this on a lift to keep the bike upright and make it easier on the old back. First, drain the primary fluid and remove the derby cover. Next remove both the driver's and passenger's footboards. Finally remove the heel shifter.
Next put lots of towels or newspapers down below the primary to catch the left over fluid when you remove the outer primary cover.
Remove the outer primary cover. Zip tie the chain tensioner and remove the two mounting bolts...be aware that there are two "spacers" that go between the tensioner and the case...they may remain on the tensioner (one of mine fell off, while the other remained attached) they're on the backside of the tensioner where the bolts go through. If they don't stay on the tensioner make sure you keep tabs on them and they are in place once you reinstall the tensioner.
You need to make a sprocket locking tool, I used a 1X2 piece of wood cut to 6 1/4" length which worked nicely. Put it between the comp sprocket and clutch assembly like shown in the pic below.
You need a 13/16" socket to remove the stock comp bolt. It's on there pretty good and I ended up using a breaker bar to crack it loose. Once the bolt is out simply remove the stock shaft extension, this will free up the stock comp sprocket and allow you to remove the chain without having to remove the clutch assembly. Use care to not bind up the chain. There's plenty of slack and room to store the chain safely off to the clutch side of the primary.
YOU WON'T BE RE-USING ANY OF THE STOCK COMP PARTS SO LAY OFF TO THE SIDE OUT OF THE WAY.
The next pic shows the stock rotor/spring assembly (2 little springs in the can that's attached to the rotor) on the right vs. the springs that come with the SE comp kit on the left. HUGE difference between the two!!!
The following procedures for installing the new comp parts are clearly stated in the SE comp kit instructions... first slide on the SE rotor
Next the shaft extension (the instructions will tell you where to apply primary fluid to the piece).
Next comes the SE springs...again the kit's instructions are very clear to what order and configuration these springs need to be in.
Next the sliding cam goes on.
Followed by the SE comp sprocket. Obviously you'll have to slip the chain back on before sliding the sprocket onto the smooth bearing journal of the shaft extension.
Finally install the thrust washer, sprocket retainer and the new bolt. Follow the clearly outlined procedure that are in the instructions to make sure you have everything in the proper place and order. You DON'T need to use the block of wood to hold the sprocket to tighten the bolt. You need a 1 3/4" box end wrench or a big *** cresent wrench to hold the nut on the sprocket retainer while you torque the comp bolt. Torque it to 100 ft. lbs, back it off 1 full turn and then torque to 140 ft. lbs. Re-install the chain tensioner (making sure the two spacers are in place) torque the bolts down and remove the zip tie.
Look over your work and double check everything over carefully before buttoning up. Install a new primary cover gasket, the primary cover.. fill with 45 oz. of Formula +, put the derby cover back on and heel shifter and finally the footboards. Once again, the kit's instructions are very clear and the whole job is what I would consider a piece of cake for anyone that has moderate mechanical skills and the proper tools. Total time was less than 3 hours. Having done it once, I could easily do it in less than 2 hrs.
Though there are no photos in the post?
#599
2008 Stock Ultra Classic (10k miles, got it used), replacing the stock comp this spring (Screamin' Eagle Big Twin Compensator Part Number 40100061).
My main question: do you have to pull the clutch to do this? (to get the chain off the original compensator & onto the new compensator etc)
I have no issue grinding a little off the case, pulling the inner primary seems like a lot of unnecessary work (to me personally)
Many of these threads don't discuss the part you need to 'glue' onto the primary cover. For mine, I will need to do that I believe. But pulling the clutch is a bigger issue to me. Would rather not mess w/ it if I don't have to.
#600
2008 Stock Ultra Classic, replacing the stock comp this spring (Screamin' Eagle Big Twin Compensator Part Number 40100061).
