Harley Police bike has different engine?
  #91
Old 11-17-2018, 10:19 AM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
See Service Bulletin M 1248 dated July 13, 2009
Purpose
Harley-Davidson has developed a fork bracket that permits a
smaller turning radius which may be required for use by
some law enforcement agencies. Harley-Davidson is offering
this fork bracket as a no-cost upgrade to those law
enforcement agencies which may require the smaller turning
radius
  #92
Old 11-17-2018, 04:49 PM
stro1965's Avatar
stro1965
stro1965 is offline
Purpose
radius
As I recall, the frame change in 2009 altered the turning radius to the extent that completing basic police motor patterns was no longer possible, hence that service bulletin. It was rectified in 2010.
  #93
Old 11-17-2018, 05:46 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,523 Likes on 1,420 Posts
So if the cop accidentally misses the turn into the Dunkin Doughnuts, He will be able to make a rapid u turn to get in there quickly.
  #94
Old 11-18-2018, 04:11 AM
GOV5's Avatar
GOV5
GOV5 is offline
Received 1,450 Likes on 932 Posts
Thumbs up
Originally Posted by thegrandpoohbah
so if the cop accidentally misses the turn into the dunkin doughnuts, he will be able to make a rapid u turn to get in there quickly.
exactly
  #95
Old 11-18-2018, 12:35 PM
stro1965's Avatar
stro1965
stro1965 is offline
Donut jokes never get old, huh? I guess you probably never partake?
  #96
Old 11-18-2018, 12:49 PM
NORTY FLATZ's Avatar
NORTY FLATZ
NORTY FLATZ is offline
Received 5,371 Likes on 2,947 Posts
Originally Posted by BUZZARD II
It might depend on how far back you go. I had a '88 FLHTP that as I recall had, higher apm output, slightly different cam and no rev limiter. It also had the only accurate speedometer I've ever seen on a bike. I checked the speedometer with radar and it was spot on. I don't know about the cam and limiter stuff. It was way faster off the line than any stock or lightly modified H-D that I knew of. But the top speed was the same as a buddy who I raced across PA. with. I could beat him in a drag every time, but for two hours WFO we were dead even. Go figure.
How large was your fuel tank? A 'busa can empty it's full tank in 18 minutes, at WFO. (Of course, you're going to travel about 61 miles during those 18 minutes, but I digress.)
  #97
Old 12-01-2018, 12:37 PM
Gary Biehl's Avatar
Gary Biehl
Gary Biehl is offline
Stage I
Default My stage1 08 flhtp embarasses similarly equipped rushmore bikes regularly in 1/8 and 1/4 regularly
Originally Posted by rmw
I've been told a number of so called facts about the police bikes, special super dupper engine, special tires but the HD Police brochure pretty well tells the story http://www.harley-davidson.com/en_US...e-Brochure.pdf
Same tires, Dunlop 407/408, standard 103 engine w/oil cooler essentially the Limited package but they do have a 50 AMP system and I think the standard is 30 AMP.
A lot of the models still in service are 96's.
my stage 1 equipped 08 flhtp embarrasses siliarly equipped rushmore bikes and 110s regularly in 1/8 and 1/4 mile trips.
it pulls too hard for em in 1st and second
  #98
Old 12-02-2018, 10:38 AM
paddywagon's Avatar
paddywagon
paddywagon is offline
Originally Posted by BoonDock_Saint
It's got a cop motor, a 103-cubic inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic convertors so it'll run good on regular gas. - Elwood
fix the cigarette lighter
ABOKOL
01-15-2018 08:33 AM
True Grit
11-09-2009 02:07 PM
vjw0307
10-14-2009 07:08 AM
txgeezer
02-20-2009 03:54 PM
liquiddeputy
01-26-2007 08:25 PM
Quick Reply: Harley Police bike has different engine?
