Royal Purple 75W-140 "not for wet clutch"?
I have some Royal Purple 75W-140 that I was going to put in my transmission. On the label it says "not for use with wet clutches". I'm assuming I have a wet clutch and shouldn't use it.
This is for a 2000 Road King.
Just wanted to double check and make sure my understanding of my type of clutch is correct.
I saw on a thread search that 75-140 was an okay weight for the tranny and bought this stuff without reading the label.
Harleys have separate oil supplies for the trans and primary, as Guntoter says, but many other brands of bike run the clutch and trans in the same oil. That warning is aimed at them, not you! Use a suitable primary oil, which is likely to be lighter weight than Royal Purple.
If you don't have a factory service manual for your bike I recommend you get one.
Thanks! This makes perfect sense. I have the service manual and 'fix my hog' video.
Even though this is a 2000 RK, I bought it as a garage queen a few months ago and it's just turning 5k miles. This is my first maintenance on a Big Twin. I did this stuff on my Sportster, but I was getting a little paranoid today about what goes in which hole.
a few years back some dealers used syn 3, harley's synthetic oil in 20/50 in all three holes. the royal purple will be fine. i use 20/50 synthetic in my motor, redline shockpruf heavy in the transmission and B&M trickshift automatic trans fluid in my primary. it's the best combination i've found. little to no clunk when shifting into first from neutral. i do tease the clutch plates when the motor is cold though allowing the plates to completely disengage. my friends can't believe that my harley doesn't clunk when going into gear.
