Today's project, gutted a 2011 2-1-2 pipe, with pics.
Old 05-06-2011, 04:45 PM
JC Turbo's Avatar
JC Turbo
JC Turbo is offline
Default Today's project, gutted a 2011 2-1-2 pipe, with pics.
Tools used:
Vice, cut off wheel, air chisel, die grinder and welder.
Took about an hour to do. This is the second pipe i've gutted but the first time doing it this way. The last one I cut in two halves and drilled the cat out. Due to cutting it in half I lost about 1/8 inch in length from the sawzall so had some trouble mounting the cross over pipe on its bracket due to it being a little shorter.
So on this one the area I cut an access panel so I didn't loose any length. I tacked the four corners and welded the panel back in place. Once mounted the cuts and welds will be totally covered by the heat shields and will look totally stock appearing.
BrownSanta (03-16-2016)
Old 05-06-2011, 05:27 PM
ezriderpgh's Avatar
ezriderpgh
ezriderpgh is offline
Nice, thanks! Can I come over and do mine? lol
Old 05-06-2011, 05:42 PM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
Nice job... What gains did you get? Thanks
Old 05-06-2011, 05:45 PM
dbell66253's Avatar
dbell66253
dbell66253 is offline
There are a few threads on this subject but I still subcribe to see different ways to do it and everybody's ideas. When I finally do mine, I don't want to have too many doubts.
Old 05-06-2011, 06:02 PM
tj316's Avatar
tj316
tj316 is offline
I'm interested in the gains too
Old 05-06-2011, 06:05 PM
VinnyM's Avatar
VinnyM
VinnyM is online now
Nice job, that access panel looks like the way to go.
Old 05-06-2011, 06:22 PM
JC Turbo's Avatar
JC Turbo
JC Turbo is offline
I did this pipe for a friends 11 Ultra he picked up on Monday. I have a fuel MOTO headpipe on my personal bike. I bought it before I tried my hand in gutting a cat from a sock pipe.
EZRIDER I have an extra 11 headpipe if u want one gutted. Where are uin Pittsburgh?
Old 05-06-2011, 07:15 PM
blueduramax's Avatar
blueduramax
blueduramax is offline
Excellent alternative way to do it! Did you weld it with acetylene or electrically? I used a 2009 head pipe for mine and put in new 12 mm bungs in the stock place. Works good so far and sounds much stronger with the stock mufflers.
Old 05-06-2011, 08:23 PM
ezriderpgh's Avatar
ezriderpgh
I live in Carrick, work in East Liberty.
Old 05-06-2011, 09:02 PM
triple buzz's Avatar
triple buzz
triple buzz is offline
like your approach to cutting. When I did mine I never thought of that. Keeps the integrity of the pipe intact.
Quick Reply: Today's project, gutted a 2011 2-1-2 pipe, with pics.
