Does your ride burn oil ?
Bought my SG new been running HD 20/50. Check my oil before each ride, always in the same spot. Run up to 95 several times. Few days ago ran the speedo up to 112. Seem like it done that easy and had more.
Checked the oil before the next 2 rides and the level was 3 marks less than its always been. Did it burn the oil or blow it out some where that leaves no trace?
Yes mine held real well for quite a while but now she uses some oil so I always just keep an eye on her. Not sure where it all goes I know some goes though the vent from the crank case up and into the intake as evidenced by the oil in the air cleaner. But she don't smoke from what I know and buddies tell me so if I am burning some it can't be much at a time. Be interesting to see what everyone chimes in with.
Correct me if I am wrong, when the vent passes oil into the breather it is also being sucked back into the combustion.
Would that change the color of the plugs or show up at the exhaust end? I wiped the end of the exhaust and there was no trace of anything.
Depends if your running dino or synthetic oil, along with a hot running new motor, probably just burned that little bit of oil up. Takes about 20,000 miles just to start to break in these newer motors since the EVO. You might have been a little high on your oil level too, every bike seems to differ where it wants to run it's level at. Your better off a little on the low side.
And I did call the dealer and ask why they put so much oil in my bike.
Their answer, the guy that did your service is not here today.
