Road King vs Road King Classic
Hi guys. I'm just cuttung my Harley teeth. Just sold my GoldWing and I'm looking to buy a Road King. My question is...what's the difference between the RK and the RK Classic other than white wall tires and the hard leather bags vs the fiberglass bags? Can the fiberglass bags be switched out for the hard leather bags? I want a 2008 or newer for that 6th gear. Thanks.
Classic also has spoke wheels, cruise standard. Yes the leather can be switched. On the 2011 the classic has the 103ci engine and the standard has the 96ci.
Go with the Classic!
the newer Classics also have ABS and security.. But its the 103 that tipped the scale for me. Under the skin, both are kings.. you may want to consider the customization that you will want to do to each and see which comes out less.. Good luck
check this out,it's in Oregon:
sale-gvmz3-2332469040@craigslist.org |
A road King hands down. The 6th gear is in my 07 King. Love the hard bags. This is actually only a question you can answer, it is what catches your eye. What do you want to change, etc....
Originally Posted by deano3326
(Post 8371227)
I had a six speed on my BMW and on my sportbike. In my opinion, you end up with one gear that is so short you it shouldn't even be there, so you still have 5 usable gears. Six speed gives you lower RPMS at Highway speeds, and probably slightly better gas mileage. But engine size and 5 or 6 speed is a personal thing. Go for what YOU want. |
Sold my Classic 2 weeks ago. Laced wheels and leather covered bags are a PITA to maintain and keep clean and the bags need special gizmos to lock them. I also prefer to run tubeless tires so I can shoot a can of glop in the tire if I get a flat out on the road. I do prefer the looks of the Classic, however, if you want to go down the road all day every day the RK standard will give you less grief.
I'd highly recommend the Classic. For me the wheels only take minutes to clean. The look and the ride are awesome. But go with the one that attracts you the most.
If I was buying new, I would get a classic and immediately switch out to the hard bags.
I like my current RK standard very much. I ride a lot and the leather looks like too much work for me. Plus the hard bags are more waterproof. |
© 2024 MH Sub I, LLC dba Internet Brands
