Stripped derby cover screw
I've been stripping screws for 40 years on everything from bikes to motorhomes to jet aircraft. I've used every tool and method described in this post, and a lot of other too. This is the easiest thing I've found for removing stripped screws, providing you have a variable speed reversible drill:
http://www.google.com/products/catal...d=0CFQQ8gIwAQ#
Home Depot has them. You'll rarely fool with easy outs again.
-Dusty
-Dusty
-Dusty
-Dusty
Thaks for posting that-- never seen anything like it downunder yet.
Always use an impact driver to break them loose and you are unlikely to ever have a problem with the torx heads.
Also to replace the screws you can go to your local stealer/indy and buy replacements
But buy the allen head screws in a button or standard style there 1/4 x 20 x 1/2 grade 8
I've been that route all ready I've got the allens in my cover and are alot easier to unscrew.
I have noticed that with torx bolts especially make sure you are using a quality tool to remove them. Do not use a taiwan junk tool, or for that matter the Harley kit. Go get yourself a craftsman or other t27. And use that bit for only the derby cover.
Drill the head of the screw off, then pull the derby cover off, then you will be able to easily unscrew the screw with your fingers or pliers.
Search, you will find many threads about this.
Make sure you have a T27 and not a T25, easy to think a T25 fits, until it strips!
Use some anti seize on the threads when you put the screws back in.
