wobble after new rear tire?
I had lots of trouble with Avons over the years. I know some guys like them. I don't.
You got a bad tire. I've been down this path... spend 6 months trouble shooting it, finally give up and throw on a new tire and the problem will disappear.
I'd bet a steak dinner on it.
If the bike is fine 2-up it suggests the pressures may be high for solo riding. In actual fact Avons routinely use higher pressures than in the owners manual, so first of all check their website for the correct ones. Do not use the max pressures on the sidewall! Also bear in mind that tyres require a couple of hundred miles minimum to bed in. I personally don't run fast or corner hard for around 500 miles on new tyres.
Just put a set of Avons on my 2007 Softail Custom (FXSTC), and now have a rear wheel wobble at ~75-80MPH.
Changed plenty of tires before, so I know the drill (belt deflection is good, etc.).
Please be aware that the wobble is not present when riding two-up.
Any suggestions?
Thanks
Any suggestions?
Thanks
If riding two-up stops the rear wheel wobble (when set at 40 PSI), are you suggesting I should use less than 40 PSI when riding solo?
Thanks
Bike has Progressive rear suspension, set at stock height.
Never had an issue with any brand of tire (stock Dunlop, Metzeler, etc.), just these Avons.
Bike previously tracked well with the worn Metzeler, started wobbling as soon as the Avon was installed.
Thanks
Thanks
When I started riding bike owners manuals came with recommendations for adjusting pressures for light or heavy riders, as well as riding 2-up or loaded with luggage. That seldom is given a thought these days or gets mentioned. Especially if you are lightweight, reduce them as a starting point. Make small changes one step at a time. If it gets worse with a lower psi, try a slight increase as an alternative. I've used Avons on my Harleys since the 1970s and always go back to them and have only had good experiences. I haven't however owned a bike with such a wide low tyre similar to yours.
steelerdude1
2014-2023 Touring Models
17
02-20-2018 01:58 PM
