Looking for some pics of the kuryakyn 2262 passing lamp
I am working on a project using the kuryakyn 2262 led passing lamps. I need so close up pics a exact dimensions of the lamps, any help from you guys would help.
I googled the heck out of the lamps but no luck.
Do you think it matters if the "dot" faces down instead of being at the top? There are 3 "dots" around each bulb. I installed mine with the dot at the 6 o'clock position. The picture shows the bulb with the dot at the 12 o'clock position. I didn't read any instructions that suggested one way or the other and I didn't notice this picture when I originally installed them. Thoughts?
I believe there is a tab on the back. Check to see if there is one. It should go in the slot on the light bucket. Pull up to a wall or your garage door (closed) and look at the light pattern. You can tell if you need to rotate the pattern.
The Kury Passing light bulb fits just as well with the "dot" up or down. I checked. The lights don't seem any different in their pattern on the wall but it's hard to tell for sure.
