Help bike stalls!
Old 07-31-2011, 11:04 AM
7x30Waters's Avatar
7x30Waters
7x30Waters is offline
6th Gear
Default Help bike stalls!
I have an 07 ultra classic, mileage is 6547, the last couple of times that I have taken it out it stalls when i down shift for a stop. Fires right back up but I have to keep feathering the throttle, runs great on the road, just wants to stall when down shifting. I am running 93 octane for fuel, checked the battery terminals for corrosion, I put a fuel pack on this spring. pulled into the driveway last night and when it started to stall, feathered the throttle a little to keep it running after a couple of times at that it, set there and idled on the jiffey stand while i opened the garage door. Any Ideas?
Old 07-31-2011, 12:11 PM
CurtisO's Avatar
CurtisO
CurtisO is offline
Unplug the fuel pack and try it. May need a different downlaod. Sometimes process of elimination is the way to track down a problem.
Old 07-31-2011, 12:41 PM
tonsa's Avatar
tonsa
tonsa is offline
That happen to me. I Called vance and hines and they gave me the right setting.
Old 07-31-2011, 12:50 PM
reisjer's Avatar
reisjer
reisjer is offline
do a search of IAC. If it's not the fuel system then this very well may be your problem. I've run into this problem with my '07. It seems the IACs used in the 07's typically displayed this problem. you can try cleaning it too. sometimes this helps. Take off your air filter and spray a little carb cleaner. There is a hole right in front of the butterfly. I think if you order the replacement part it's right around $40. Do you find this problem typically after you've done some highway riding and you're decreasing your speed from around 70 to 0? Shifting down into 1st it's as if the bike doesn't know where idle is?
Old 07-31-2011, 01:51 PM
7x30Waters's Avatar
7x30Waters
6th Gear
stalls when down shifting from any speed, when pulling in the clutch, throttle response is right on when up shifting, when crusing throttle response is also right there. If i keep the throttle turned up a little when stopping it will eventually idle. I will unplug the fuel pac and try that.
junior166745151
11-04-2013 12:50 PM
Anoldbastard
07-25-2013 02:06 PM
Georgepty
04-04-2012 09:44 AM
jaystay42
Exhaust System Topics
08-06-2011 08:10 PM
mkizer
06-29-2009 11:00 PM
Quick Reply: Help bike stalls!
