Can you add the intercom to Street Glide
Old 08-08-2011, 06:27 AM
Audioi's Avatar
Audioi
Audioi is offline
Default Can you add the intercom to Street Glide
Thinking of a 2012 SG but really like the headset intercom. Is there a upgrade kit available anywhere?
Old 08-08-2011, 06:53 AM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
There are a lot of aftermarket intercoms out there...If you want to upgrade with Harley components it will get expensive...I think you will have to buy handle bar switches C.B. overlay Harness and the fuel tank center console.
Old 08-08-2011, 07:05 AM
batman4706's Avatar
batman4706
batman4706 is offline
Default Intercom
You can buy Scala Cardo Systems Q2 or G4 set and go wireless. Would be a lot cheaper, maybe $150 on ebay for the Q2.
Old 08-08-2011, 07:52 AM
Audioi's Avatar
Audioi
Audioi is offline
The factory setup on the Ultra kept the wife happy with her own radio controls.
Old 08-08-2011, 08:16 AM
sh57's Avatar
sh57
sh57 is offline
I added the intercom and cb to my classic. Got all the parts I needed off this forum. Just took awhile to get everything I needed.
Old 08-08-2011, 08:20 AM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
HD offers two kits (77107-09 and 77108-09A) for adding intercom w/o a tour pak and w/o changing the tank console for adding the rider headset connector. I installed the 77108-09 kit because I was also installing the CB and described the installation in this thread:
https://www.hdforums.com/forum/touri...tra-glide.html
My installation was more complicated because I was retrofitting the kit to my '04 so the left side handlebar switch harness connector needed to be changed, and a simple wiring mod had to be made; neither of these changes would be necessary on an '07 or newer model and installation is essentially a plug and play install.
If you have no interest in adding CB, get the 77107-09 kit--it will be less expensive overall since you won't need to purchase the non-Ultra overlay harness (NUOH, list price ~$129) required for the 77108-09A kit.
Good luck with your project.
Carl
Old 08-08-2011, 08:43 AM
hog95023's Avatar
hog95023
hog95023 is offline
Thanks for starting this thread. I have been searching all weekend for the same answer.
Old 08-08-2011, 08:47 AM
hog95023's Avatar
hog95023
hog95023 is offline
Harleypingman, is the nonultra harness needed the sme harness I needed when installing he hd cm radio module on my sg or is there a different one?
Old 08-08-2011, 08:48 AM
hog95023's Avatar
hog95023
hog95023 is offline
Xm not cm radio
Old 08-08-2011, 09:13 AM
Audioi's Avatar
Audioi
Audioi is offline
I thought the harness was the same on all of the dressers after 2008?
Quick Reply: Can you add the intercom to Street Glide
