So.. I got a power commander.. But uh.. What's it do?
I bought a power commander for my 2011 rk. But I have no idea what it is going to do?
I have dresser duals and high flow ac... I know I need it to make my bike run correctly.. But what if and performance increases is it going to give my bike? |
In the same boat , tell us how to work these things , please
In short, it richens the air/fuel mixture so that your motor doesn't blow itself up from the lean condition resulting from the increased airflow caused by your less restrictive air filter and exhaust system.
Why'd you buy it if you don't know anything about it? There's other options out there, but that's probably the most popular. |
Here is a good thread that will give you a lot of information on the PCV ECM.
https://www.hdforums.com/forum/touri...-autotune.html |
If you have had a map preloaded onto the unit then its just put and play. If you just bought one off eBay or a store shelf then it just comes with a generic map and you will need to go to Dyno Tune's website and download a canned map for whatever bike you have and for whatever parts you (or someone else) have put on.
Originally Posted by usmc3468
(Post 8711313)
Hmmmmm.. They do have instructions........... Why would you go out and buy something without some input on what you are buying???
If you have had a map preloaded onto the unit then its just put and play. If you just bought one off eBay or a store shelf then it just comes with a generic map and you will need to go to Dyno Tune's website and download a canned map for whatever bike you have and for whatever parts you (or someone else) have put on. |
And there are 2 guys that don't have a clue about what they bought. Priceless!
Since you have no idea what the PC will do, then I recommend you carry the bike and the PC to a certified Dyno shop, let them install The PC and tune the bike.
I have no idea either which is why I bought an EMS. :icon_nut:
© 2024 MH Sub I, LLC dba Internet Brands
