Bike sitting for 3 years
Use synthetic motor oil in the motor, use primary and tranny fluid in those. I use the H-D stuff.
Tires- very important you don't wanna tire coming apart on you on the highway.
do you live where the temperature swings and condensation can build up? may flush the brakes.
gas tank- ALWAYS store a tank all the way full or all the way empty ( and open)- otherwise condensation will form and it'll rust from the inside out
battery- always remove battery from a stored bike
start ups- Do NOT start the bike up for short periods while stored- yes it moves oil around- BUT it gets the cases just warm enough for condensation to form, and the cold motor will have blow by between the piston rings and cylinders, washing down the oil. The oil will not get hot enough to burn that off. the acids in th eoil and water will eat the bearings.
When I store vehicles, it's fresh oil in- spark plugs removed and oil added to cylinders. bike in gear, rotate the rear wheel to move fresh oil into the motor. raise tires up off floor, wax and cover.
Waking up, again oil in the cylinders, then use the rear wheel to get everything moving and oil to the top end.
remember that lifters need oil in them, so may be clatter on start up if dry.
mike
mike
I'm with MK on the gas tank issue. I stored my bike one winter (Nov. - Mar.) with the gas tank half full. Didn't realize I had a problem until my bike died in the middle of a main thoroughfare...turns out the tank rusted from the gas level up and rust clogged my fuel filter. Final cost= a tow home and the pain in the *** to treat and coat the inside of my tank. Thankfully I learned this lesson during my sport bike days....never looked at one of those as my baby like I do now!
Yeah that !.....Fill it full of premium and you'll be good to go. You don't need to cuddle it.....real motorcycles don't like that. Don't let the extremists get you shook.
I would just check the fluids and tire pressure. Based on your location, you probably have not had any temperature extremes. It's not like you have a "barn find". Three years is not all that long, I have seen "new" scooters on dealer's floors that long.
