Bike sitting for 3 years
Didn't see much said about the electrical connections. I would also disconnect the two grounds to the frame under the seat, clean, coat with dielectric grease and reconnect. I would also have to pull fuses and make sure they are not corroded. Connections to starter. Sitting for three years the electric connections will develop a layer of corrosion. Check all the other connections under the side pannels. New security fob batteries if you have security.
If it ws ME....
Check the tires for rot......put gas in and go. Change the fluids when you get home.
It's been sitting inside and you have started it frequently enough that things work. If the tires are good...then just go. You have AAA and a cell phone if something goes wrong.
Sounds like a fun trip!
~Joe
~Joe
WOW!!! Way too many overly cautious folks out there. But to each his/her own.
Fill the tank full of Premium, add a lil stabil, change all 3 holes, inflate and inspect tires. Everything else can be checked while you're out riding prior to your trip.
Enjoy and have a safe trip!!! Let us know how it went upon your return
My biggest concern would be the tires. Give them a real close look. I had a bike sit two years and the tires were permanently bulged at one spot on the sidewall. Looked good other then that and it road with a slight vibration. Put the bike on a lift and roll the wheels while you watch them. Otherwise blast off after normal preride checks.
Nearly every post mentions inspecting the tires. Forget that; look on the side of the tire and find the date code to see how OLD the tire is. If it's more than 5 years old, you might want to consider getting fresh ones. I just changed a front tire and tube on my "new" shovel and was shocked at the condition it was in. It was a wonder it rolled without exploding. That bike had been sitting for 2 or 3 years after being ridden regularly for 30 years prior. No, it wasn't an original tire.
I would do a complete service on that bike and would also be riding it every day prior to the big trip in order to look for oil leaks that could pop up due to dried gaskets. My garage queen rescued Road King started leaking oil from the rocker box covers shortly after I got it. You don't want that on a long trip.
I agree with "who?me?" definetly if you have a fob, get new batteries, I just can't imagine not riding a bike for 3 years, unless I had a bad accident or had to go away... hope that's not the case, but whatever, do all the checks, and fluids, get used to the bike before you attempt to ride anybody, and remember the cagers still see you as a target, ride safe and enjoy.
