Anyone Bought a Drag Specialties Battery for their Touring Bike?
I haven't had any dealings with Drag Specialties, but I did replace my battery in July with an ETX30L from BatteryMart.com for under $100. shipped. HD wanted $170.
Furthermore when I took it back they wisked it off to the back of the shop to load test it and then pronounced it "just fine" and suggested I have them fix my stator for $1000. I told them thanks but no thanks, went down the road, picked up a H-D battery and have had it ever since. There was nothing wrong with the stator. That was the last time anyone but me worked on my bike. The indie told me the battery was out of warranty so tough luck.
Personally I would only ever buy an H-D battery or one that I knew for a fact was made by the same company (I forget which company that is but someone here's bound to add that info. If not do a search).
(this was on my Fatboy - about 4 years ago).
1 Post
Do I need to do anything special or take any special precautions in installing a battery in my 05 EGC? Any tips or advice? What do I do with the old battery?
The Deka is rated at 650 CCA and the BC is rated at 400. I'm getting a Deka in the spring.
Hmmmm, the Big Crank battery from Battery Mart. Looks very interesting. Only $97.95 with free shipping. It appears to be the same battery as the Deka (which costs about $12 more), but I could be wrong about that.
I have been using a Drag Specialties battery in my bike for the last several months. First one lasted but Two or Three days. I figured it had just spent to long on this Kawasaki dealers shelf, as they ordered it for another customer some time back. I also didn't get instructions to charge it before installing it. I had only checked the surface charge before installation. So in retrospect, it's premature demise might have been my fault. Ida kno?
They checked it and had already had me replacement ordered. Easy switch out and have been a happy camper so far.
And I believe that DEKA is HD's factory gel battery.
Yes, their are steps to take in your batteries replacement Chas.
First and foremost, as all repair descriptions in the manual start with, "Disconnect the Battery".
This should be the only instruction you should incorporate for said replacement.
The only difference I remember was the battery terminals reconnect on the front side of the battery as opposed to the top where the stock battery connected. NBD
My $0.02
aka Bob
My $0.02
aka Bob
My Stock HD battery crapped out several weeks back after 2.5 years of service. The nearest Harley dealer is 70 miles away and the HD battery is $170. I went to a local indy shop and purchased a Drag Specialties battery for $119. It is an AGM battery just like the stocker plus it comes with a better warranty. The battery comes without the acid installed. The indy put the acid in, sealed it and then put it on charge overnight per the instructions. I picked it up the next day, installed the battery and though only three or four weeks have passed, I am pleased.
For what it's worth. The parts guy at the Harley dealership referred me to the indy I went to. Suggested I try the Darg Specialties battery.
