Compensator sprocket/Hard starting/b1006 b1007
1 Post
Hello everyone.I recently had my bike in(Warranty work) and had the se compensator sprocket installed(or so the said they did).The noise in the primary seems to be a little better and not such a clunk when letting off the throttle. My problem is now after riding for a while,and bike is warm,when I go to start it again,it seems like it isnt going to start then I get a banging noise and it starts??
Any one out there had this issue? Any Ideas? I am now always getting Fault codes b 1006 , b 1007 as well?
Thanks for any help,
Dean....
Dean....
You should not get the banging with the SE comp. My guess is they never installed the comp & charged you for it. Dealers will install the SE comp under warranty,providing you make up the difference in price between the stock & the SE. Did they charge you anything? If not, they prolly lied about installing the SE. They should NOT clunk.
1 Post
Here ya go. Not sure which one is correct but mine is an 07 and they had one for it. http://www.mesmotorcycle.com/street.htm
LoveHate
11-18-2014 11:36 AM
speakerfritz
07-14-2012 01:08 PM
