Mine loosened up on a ride and was running out. Luckily we had the tool to get one of them good which held till I got home and was able to really get at it.
are you talking about the intake manifold wrench ? i have one, and mine were loose on a ride also glad i had it, don't know how many times I've used it on all my buddies bikes were theirs were loose. glad i got it.
Just pulled mine apart yesterday to check for a leak. After I pulled the exhaust it was very obvious that it was those bolts. I blue lock tited them and torqued them down. Now in the process of reassembly so I can go for a ride.
Ok never mind Beary I know the bolts your reff to....I was in that area when I pulled my header to cut the cat out..I will check that regular thanks for the heads up.
Hey Beary, could you clarify which bolt your reff to that if loose will cause a leak? Odd that a hanger bolt missing or loose would cause a leak, that would imply this bolt is threaded all the way thru to the fluid reservoir? that's a weird design flaw don't you think?
